1 - 8 of 8 Posts
Hi I know I may sound really ignorant ... but what is this white tank on top of the cylinder under the tank? It is kind of behind the battery. Should it be empty? The fact that is empty could be the reason why my 748 is not starting? Thanks!
Interesting ... so it shouldn't be empty even if the bike is stopped. I really need to take a mechanics course or something...
Thanks ... it is full, I looked it up today. At this point I need to charge the battery then see if the bike starts... it may have been some bad gas from last spring
If you get coolant in the overflow tank it normally gets sucked back into the cooling circuit/reservoir at a later stage. Don't worry if the tank is empty. It is perfectly normal.
1 - 8 of 8 Posts
