I've read somewhere on this forum about how to resolve a leaky clutch fluid tank lid but I don't seem to be able to track that down. Am I the only one with that problem? If not, which very likely is the case, what have others done to resolve that issue? I've removed the lid a couple of times and refitted it but it keeps leaking. Would it suffice to just change the lid or does one need to replace the entire tank?
2013 GT front brake reservoir does it too. I've noticed it helps after having sucked off some of the oil.
Syd
2017 1200S and the front brake reservoir started to leak yesterday whilst out on a ride, only a very small amount but definitely coming from the lid, it also looks like the reservoir is overfilled, so i will be removing a few ml of fluid and cleaning and refitting the seal and lid. If that doesn't fix it then back it goes to the dealer.
