02 ST4S. First decent ride of the season and I find mayo in the sight glasses on both sides when I get back.Too hot and long a ride to still be winter condensation.
Drained the water and oil...no oil in the coolant which has got to be a plus.
Pulled the alternator side cover off and found heaps of mayo around the water pump and inside the cover.
One of the pump's ball races is rough so I'll replace both of them.
What do I need to replace as far as the seals? do I need to buy a whole new impeller with the spring part of the seals attached or can I just do the rubber and ceramic bits?
Thanks.
Thanks.
