1 - 9 of 9 Posts
I went out for a ride yesterday and once I got home I noticed coolant dripping on the right hand of the bike. The coolant was definitely not leaking while riding only once the bike was turned off. I followed the leak and it seems to be coming from the fitting on the top/right hand side of the radiator.
I'm not one to get the dealer involved for a coolant leak. I haven't had time to dig into the issue but anything I should troubleshoot first?
This was pretty common when they were new - if it's not the weld at the fitting (I've never seen one crack but there's always a first time) give the clamp a twist - should clear it right up.
It's definitely coming from the weld not from the clamp. Are we sure those two parts are welded together? I'm hoping it's a busted oring......
There's definitely not an o-ring there. As long as you have someone in your area that's good at radiator repair they should be able to repair that area fairly easily. However, you will need to remove the radiator and take it to them to do the repair.
Reactions: flynbulldog
Bon Vivant
No like squirrel said that fitting is part of the radiator - "weld" is probably the wrong word its probably brazed or soldered. radiator shop for sure. Can you see a crack in the pipe?
Discussion Starter · #7 ·
I definitely can't see any cracks. Could this be a problem caused by something else? I don't want to fix the radiator only for the coolant to find the next "weak" point in the system to escape from..... It only leaks once the bike is turned off after a ride. I know the pressure goes up once the bike is turned off due to the heat. Where is the extra pressure supposed to escape normally?
Bon Vivant
There's a thermostat that should release coolant into the overflow tank if the system get too hot. If its leaking at the rad it will need to be repaired eventually. Honestly, usually its just the clamp - even if it looks like its coming from the pipe, it wont hurt to screw that in a turn...
1 - 9 of 9 Posts
