So I have been working on replacing all of my fluids on my 2005 800ss and have found a leak in the push rod in the master cylinder.
For some context the person before me didn’t maintain it well and the fluid was mixed with shimmering metallic pieces. I realize this is a glaring issue but I planned to flush it and if anything happens then I would deal with it.
I flushed all of the fluids and found that the dust boot that covers the pushrod was ripped so I pulled it out and plan on replacing it. After this I realized there was a slow leak of fluid coming out of the pushrod seal (I assume). My clutch has worked fine and hadn’t noticed the leak until I took off the boot.
Should I spend time to take it apart and try to rebuild it (I’m slightly inexperienced). Or should I just buy a new one.
