What a bummer. The 999r gas tank is leaking at the rear seam. At the dealer for a hopeful repair via POR internal tank sealing. The leak was very very suttle and I confirmed had nothing to do with the fuel pump area or hoses. On the upside while the tank is off I am having the fuel pump replaced as well as the passthru wires.
How many miles. I just bought a xerox and will want to keep my eyes peeled for that issue.
Wouldn’t do the por bit until you find out if it’s rust or a crack. No tank liner will work with bad prep and that means lots of work and ALL moisture heated from any seam and with lots of warm airflow. I see the results of poor prep and a liner every couple of weeks.
