IIRC, those rubber double-ended stand-offs are about $8.00 from the dealer last time I bought some. I removed my cluster to replace a burned out bulb and one of the stand-offs was separated from the threaded portion.
BTW, don't reef on the mounting nuts when putting it all back. Over-torquing them will pull the threaded stud right out from the rubber body. Finger tight into the cluster; just snug on the mounting nuts.
