I've had mine off a few times. IIRC, all you need to do is remove the spring, unbolt the switch, unbolt the stand and unplug the electrical switch. Don't forget to stow the switch wiring that's left behind on the machine.
Take a closer look...you might be able to remove the stand bracket that's attached to the engine too.
