Mine is cracking, does anyone have a source to replace this gasket/rubber that installs around the key guard to keep from scratching the tank?
Not a bad idea, thanks.Very narrow rubber tubing, pulled over a narrow dowel, and carefully sliced down the middle with an exacto blade, cut to length and slipped over the edge of the key guard. Or, try ordering one from the closest dealer.![]()
