I've only had my 2016 DVT for six months but I've drained two key fob batteries already. It seems they last me about 3 months. I keep my key fob in my jacket pocket and I hang my jacket about 4 feet from the bike. I can usually start the bike without moving my jacket; it's hanging close enough to start the bike, at least until the battery starts to fade.
I'm wondering whether my battery drain is caused by the fob being so close to the bike 24/7. Maybe it's constantly searching for the ignition press, expending energy in the process.
I've read some threads about the position of the red switch, some suggesting the switch should be in the upper position to prevent the bike from searching from the fob. But that's the position I always keep it in.
It seems it would make more sense to put the red switch in the lower position where the bike could not be started. It wouldn't be looking for the fob if it's in that position, presumably.
And it doesn't sound right that the bike would not search for the fob if the switch is in the upper position because that's the position you put it in to start the bike, when it needs to find the fob.
Bottom line is I'm draining the battery when I keep the red switch in the upper position. Have not tried the lower position but I intend to after I replace the battery.
Any user input will be appreciated.
