I have 39mm Keihin flatslide carbs on my 1995 900SS CR. I have some questions about these. When I first start the bike I go through a ritual where I turn the throttle 4 times then push start. That's what it seems to like. Then, I have to let the bike run at idle for a while to warm up. Even then, for the first ten minutes after it runs like crap until it's hot. After that it's good to go and runs like a champ. Why is that?
Does it have to do with these carbs dumping too much gas in at first and that causes the surging and popping or is it that they don't put enough gas in when things are cold and not warmed up? My guess is that they dump too much gas in. How does a cold or warm engine impact running condition with aftermarket carbs? These were installed by a Ducati dealer with tons of experience dealing with these carbs so I don't doubt that they were put on incorrectly and I've been told that this is just a characteristic of these carbs, things need to warm up a bit before the bike runs right.
There is no choke when you use these carbs so the bike just has to sit in neutral for a while and heat up. The longer it sits the better it runs when you finally go. If you fired it up and took straight off it would run like crap for ten miles. Why is that?
And keep in mind that I've probably spent more money on my little 900 in mods than just about anyone alive (pending a few even more crazy people - and yes, I know you are out there). It has just about everything you can do to one. Dyna coils, race wires, new plugs, the works. Only thing it doesn't have is a lightened flywheel, a big bore kit, billet wheels, and a front fork swap. Other than that you name it, I've done it.
As always, I appreciate your responses.
