ciao a tutti -
cleaned the BMC air filter on the hypertard for the second time since installed ... i had forgotten what a pita it is, even with lifting the fuel tank as far up as it will go without removing it. i imagine anyone watching this process would be reminded of a monkey f'ing a football, from all the strange contortions one must make to remove the bolts that hold the airbox lid on ... then tighten them up when finished.
also took this time to wrap the wiring that runs under the tank strap, so that no damage occurs from vibration and chaffing when riding. so ... even if you don't have the ca-cycleworks tank installed, the stock tank to tank strap fit will still allow chaffing of these wires to occur.
two other items i addressed during this mini service:
ciao a tutti,
johnc
- i reapplied anti-seize to the airbox lid bolts. i did this last time, and the bolts stayed tight, and came out easily, not stripping/pulling the inserts in the fuel tank.
- i re-routed the diagnostic data-port plug that hides under the right side tank cover, so that it now hides behind the right side tank cover's inner black plastic cover. now, to get to the diagnostic data-port plug, i only need to loosen the three quick release plastic screws and remove the black cover. i got this tip/idea from billy ... grazie billy!
ciao a tutti,
johnc
