We want it all...the retro style but the performance too..
I have a customer with an amazingly clean 07 Sport 1000. DP cams..TPO beast and Staintune bi posto...1800 miles... wants a dry clutch conversion. To the best of my knowledge..a couple seals and a new case side...Actually, the primary gears need swapped too.
NOT TRUE AT ALL!
The wet clutch ds1000 engine's drive shaft is 15mm shorter than the dry version...IN FACT...its the same drive shaft as an 848. We were planning a Dukabike slipper, clutch venting on the case cover and all.
WHAT AN EFFIN train wreck! The only way we got it to work was the recently released dry clutch conversion for the 848 evo. Which actually is a bargain considering its $1600.00 and includes the slipper (hub and basket), clutch pack, primary gears, case side, seals, and even a clutch cover. We still needed to machine down the rod 2/10 of a mm because the needle bearing inside the drive shaft was too tight straight from Ducati.
Just figured I'd share that with all you guys with wet clutches who have aspirations for clatter!
Obviously we used our custom vented cover (thanks FAST FRANK) and a Speedymoto clutch cover...
NOT TRUE AT ALL!
