It should be between 17 and 20 times the compression ratio. In your case, between 187 and 220 psi. This is after the rings wear in, of course. I don't think that takes very long though. I do not know if the cams in these engine effect the test, but according to what I have read, a more radical cam can reduce the reading by 10 psi or so. This is only at cranking speed, obviously.I installed some 11:1 je piston wondering what a normal compression reading so be with stock heads and cams 91 900ss
