1 - 10 of 10 Posts
Looks like a lot of links are dead and screenshots missing from this site. How do you get to the dang locknut on the top cap and bleed the cartridge?
Loosen the top cap... Take the fork/s out... Turn them upside down and there's a big Allen key up inside... Remove that and the whole fork comes apart... Very easy to strip..
Sent from my SM-G955F using Tapatalk
Is the metal spacer under the cap obstructing the aluminum 15mm nut under the cap? Does that pry out too?
The key to these forks is bleeding the bladders. In my experience that's usually not properly done from the factory. These videos don't address this issue. The fork oil change does not change anything except bearing lube.
I just went with the Andriani and never looked back.
1 - 10 of 10 Posts
