I downloaded the free "trace tuner" app and was able to use it with my stock headphone mic to tune my belts to 110 Hz. Surprisingly easy.
I did not have the offset wrench, so I came up with this maneuver using an allen wrench stuck in the eccentric, levering against the socket, that allowed me to loosen and tighten without upsetting the mobile tensioner position.
Mayor of Simpleton
Well done, but remember that 110Hz is for new belts only. If you are checking existing belts, I believe the spec is 85 Hz.
