1 - 17 of 17 Posts
hey guys,
first off, these forums have saved my life with my 848 and i hope they can save my life with my motard -- so a big thanks in advance!
i picked up a 2008 hm 1100 just about two weeks ago for a steal of a deal and have been making some incremental changes. yesterday i put in my competition werkes integrated tail light and in my opinion, it looks excellent
im having a slight issue however, when soft wired (correctly), while using an indicator, the other side of the light will pulse the brake light. ive attached a video of the issue below -- so for example: when signaling left, correctly the left side of the taillight will blink with amber and running light, but on the off-flashes, the right side of the light will flash the brake light -- and the same for when signaling right except reversed.
i want to note that ive spoke directly with comp werkes and theyre super helpful but due to the age and nature of the situation they couldnt provide exactly the work around. im 99.5% sure it's not the light and that it has to do with the ol "resistor/relay" fixing.
i also want to note that when i bought this bike it didnt have the stock handguard/turn signal/mirrors in the front, and just had nothing up there at all, so im not sure how they were removed and whether that may or may not be contributing to the issue. since getting the bike ive added some bar ends/mirrors and im loving how it looks, just praying i dont have to dig into the handlebars and screw with resistors in the front to fix this issue
any help would be GREATLY appreciated .. to reiterate, i dont want to fix the hyperflashing, i just want to fix the opposite side of the light pulsing
thanks,
andy
andy, i think going with the cw light is a good start, i didn't do this and needed a complicated workaround to get mine to work with a light off ebay - had similar issues to you
if i'm right the cw light has separate positive and negative wires for each of the blinkers - this is important because on hms its the negative wire to the blinkers that is interrupted, so you can't use a common earth/negative - each must have its own wire
in case you didn't realise, there is a hidden menu on the dash where you can set the blinkers to incandescent or led
not sure but i think you need front blinkers
in the end i went with front leds, but needed to wire in incandescent bulbs for both sides to get the dash indicator to work - i have them under the seat - not ideal, but it worked
hope this helps
rory
hope this helps
rory
hey rory, thanks for the reply — right, each blinker has a positive and negative, but so did the stock incandescent signals! also, i tried the hidden menu, and when i get to Indicator and switch it to LED, it gives me a ‘NEN’ reading, and won’t allow it to save — i fear that that comes up because there’s no front signals. ugh, yeah i’m dreading having to do that, i’ve never actually looked at the front wiring set up and am not even sure where the wiring is located — i’m assuming in the handlebars right? and the other end goes under the seat where the back is? regardless, still chipping away at it, thank you for the brain food!
Do you care if they blink a little faster than standard? If not, there's a very easy fix for this.
I had the same tail light you're using and I was able to make it work by trial and error. This diagram from Aviacompositi illustrates what I did although I omitted the resistors since I actually prefer the slightly faster, eye-catching blink rate.
1008717
Discussion Starter · #7 ·
here’s my issue, i have it wired this exact same way — it’s the only way the signaling will actually work (obviously minus the resistors) and i get the opposite side brake light pulsing
Are you absolutely sure? Are you really using a Comp light or a Chinese version? It sounds like you have a shared ground for both the indicators and the taillight.
Discussion Starter · #9 ·
yep, ordered it from OEMcycle — came in original packaging and all — and hmm, each signal is wired to its own ground. i’m fearing having no front signals at all is what’s causing it? should i try maybe wiring the grounds together, could one of them be faulty?
Hypermotard 1100 EVO SP Corse
Does the 08-09 have the LED setting in the cluster menu for dealer installed LED turns?
Discussion Starter · #11 ·
it does, i’ve accessed it twice in the Indic setting i’ve switched to LED and both times it has said NEN and doesn’t let me leave the menu without turning the key — im assuming it’s because it’s not communicating with the front signals? not sure
Yes! That could very well be the reason.
i had the same issues with a common earth - computer says no
i'd try attaching some front blinkers - to the front blinker wires - this might work but it might not light the dash indicator light
a process of frustrating elimination
Discussion Starter · #15 ·
messaged you on another thread, do you know where i can find how to replace front blinkers? i cant seem to find a how-to or an easy manual explanation anywhere...yet everyone in these forums seems to say it's so easy? what is the process?
the wires for the front blinkers on my bike are on the left side under the front of the tank - i didn't remember till looking just now, but i didn't use the front wires - you can see the empty connectors
you can just see the 2 black covered wires coming from the leds and i extended these wires back along the tank and connected them to the rear blinker wires - i think i did this because i didn't want to butcher the standard connectors - if you don't care you could just cut the standard conectors off and connect the leds to them - but if you dont want front bllinkers you could just connect leds to the rear wires and put them under the seat
good luck
1009084
1009086
1009087
Discussion Starter · #17 ·
good luck
appreciate you my man, thank you!
1 - 17 of 17 Posts
