I can barely see the numbers and symbols in my dash. The backlight works ok. Adjusting he brightness works as it should. But it just doesn't help at all.
The display is like a digital watch or thermometer with low battery voltage. If you look at it from angle of 130..160 degrees (from side or from above) the symbols show more clearly.
So did the lcd panel blow up or what? Luckily it is still under warranty.
