I looked through the Supersport posts and could not find any info on syncing Keihin FCR 41's. Does anyone know if there are any step by step instructions on this procedure floating around on the net?
Thanks
Thanks
seriously - time to play my grumpy old man roleI looked through the Supersport posts and could not find any info on syncing Keihin FCR 41's. Does anyone know if there are any step by step instructions on this procedure floating around on the net?
Thanks
True....but you should still check sync if you've just bought the carbs especially if they're used....sync is RARELY needed on banked versions....
