Is it possible to install ABS and TC on a M1100? Feel assured knowing that I have it to use should I ever need to.
you would need an ECU, loom and sensors from a bike with it that matches the existing connectors in your bike, particularly the fuel injection harness for the TPS, injectors etc. then you need to be able to mount them which means likely modding your fork legs and swingarm to accept the sensors and the trigger wheels need to be on the wheels.....Is it possible to install ABS and TC on a M1100? Feel assured knowing that I have it to use should I ever need to.
Which possibly also means replacing wheels/axles to mount the wheel speed sensor, right?you would need an ECU, loom and sensors from a bike with it that matches the existing connectors in your bike, particularly the fuel injection harness for the TPS, injectors etc. then you need to be able to mount them which means likely modding your fork legs and swingarm to accept the sensors and the trigger wheels need to be on the wheels.....
Time to upgrade to a bike with T/C and ABS std.
Wheels and axle should be fine, the wheel speed sensor mounts to the forks and swingarm, which might actually cost more to swap out than the wheel.Which possibly also means replacing wheels/axles to mount the wheel speed sensor, right?
