1 - 13 of 13 Posts
Got a few questions on installing a front sprocket. I've got the service manual, and it says you have to slack the chain, and break the chain apart with a tool. Does this really need to be done? I would think you could just unbolt it, slide the sprocket off, replace with the new one, and just keep the chain together.
Any suggestions?
Larry
PS - I'm going one down in the front, so I can keep the stock chain.
Sprocket replacement
Just replaced my front sprocket last week and had the same thoughts going in... Unfortunately, you will need to break the chain, as there is not enough clearance to simply remove it from the front sprocket, regardless of how slack the chain is. Make sure to have a proper masterlink on hand. Good luck and enjoy your new powerband.
Wow. Congrats to those who were able to replace the sprocket without removing the chain. That didn't work on mine.
Had to do it the hard way.
Tron said:
I have the idea that you can unbolt the sprocket, slide it off with chain attached to it, replace sprocket into chain, and slide back on? Am I wrong on this one?
it can be done but the rear wheel should come off first, that is the easist way. or at least pushed forward enough to get the chain off the big sprocket first. "you can do it!" :think:
Front sprocket removal
Ist Duc is correct. Loosen the rear wheel and move it forward to loosen the chain. Remove the retaining screws for the clutch master cylinder and carefully move it out of the way; then remove the front sprocket. No need to remove the rear wheel. This is a 10 minute, or less, job. Make sure no one pulls the clutch lever while you have the master cylinger off.
Good stuff -- thanks!
1 - 13 of 13 Posts
