1 - 3 of 3 Posts
Hello,
Today i will install the Healtech quickshifter on my 998.
Do you guys have any experience with the time adjustment.
This system i very nice because it don't use an pull push swith but a sensor module bolted directly on the gearlever who is bolted directly on the splina axle.the system should be plug an pray i mean play.
The price here is 299? you can do the adjustments with your phone connected with Bluetooth!
I will test it and let you guys know if it's really that good.
And if you guys Beebe some experience with this system let me know!
Groet stefan
Just did some times for Annitori Quick Shifter on my 998.
It seemed to be best at 65ms compared to the newer coil packs like the 999s and up which like 50ish
I don't know if this will help your not since it is not the same quick shifter.
Ron
Thnx Ron!
Normal is the cut-off time the same but i will start with that value!
Next sundag i will test it on TTassen!
And i will let you know what came out.
Greets Stefan
1 - 3 of 3 Posts
