Got around to mounting my new P7b Spectrum Full Power Lithium Battery today. If any newer Hyper owners plan to go this route make sure to ask for the 90 degree battery terminal adapters as out batteries are on their back & you need them to mount the cables. Also, if you go with the smaller one like I did you will need some foam to fill up the box & raise the battery. I used some that I had from an old Shorai.
Nice clean install & fires the bike the same as the stock Yuasa which has been a great battery too & at 2 years old still holds 12.8 volts. Best part of the new batter is weight difference, 6 pounds!
Thanks to Jason at Full Power Spectrum for answering all my questions.
Here are a few pics...
