1 - 2 of 2 Posts
When was the first SS with injectors and what type did they use? Anyone know how may types SS models have used?
Thanks
Excel Addict
2001 900SSie
Fuel injected SS
The 900SSie was introduced in 98 and the 750SSie in 99.
Both used the Magneti Marelli 15M ECU. The 900 for sure used the "Greentop" Weber injector and I believe the 750 did as well. If you look at the injector on a 900 you will see that it has green on it, hence "Greentop"
The attachment shows the specs of Weber injectors.
Richard
1 - 2 of 2 Posts
