Thanks Dodge2Dub,
If I had a MS4Rs I would definitely know what rpm the rev. limiter is set to (by the method you are suggesting, hehe) - case is I don't..
Thing is, I have an MS4Rs engine on hand (no ECU) and want to run it on an non-original ECU with a modified chip (fuel/air + ignition). I'm not interested in over-revving the engine and thus want to set the rev. limiter to the original set.
Hasn't anyone bounced the rev. limiter on their MS4Rs on dyno or road, and is able to state the actual number?
Please..?
Regards M"
