I'm rewiring the harness on a EFI Ducati with the MM ECU, its an S2R1000 specifically, but the theory applies to the SBKs too.
I've energized the gauges but I cannot get the gauges to sweep. Ive supplied power to the KEYLOCK and I have 3.4V output from the gauges to the antenna ring. Does anyone know what causes the gauges to wake up and sweep? is it just the magnetic field generated by the RFID AFTER the antenna has been powered?
I've attached a link to how I understand the wiring diagram and in this manner, (if I understand correctly) if the key passes through the ring, the gauges should wake up.
The ground for the Gauges is connected but not shown in this diagram.
