Hello everyone. Am new here my name is folly. Pls I need assistance. I own a Ducati Panigale 959 2016, have been using it for a year now. so few days after the long Covid 19 break. So I decided to ride my bike which I tried to start but didn’t come up. So I use my car to jump start it which later started. So few mins later I stopped to fuel the bike and turn the ignition on again Agee fueling. but didn’t come up. Had to call a friend to help me out which we both find a way to take it back to my house. After losing everything and changing the battery. Still not coming up, so we open the ignition and find out the immobilizer has issue shaking it and it will go on and off from the dash . One chip as Bunt and removed. It was very hot at that moment that we opened it. So now pls I need help. If am getting new immobilizer which is hard to find or I should get the whole full ecu with set of keys and immobilizer so all can work together. So that I won’t need to do programming on the new key am getting. Pls I just need advice pls. And also where to order from. Thank you and God bless u.
If the 959's ignition operates in a manner similar to that of an 1199, then the ECU is a nonissue. If you have a functional ignition switch and a valid key, then you're good to go. A replacement ignition switch kit for the 959 is available from Ducati and includes the switch, a new fuel tank cap, two keys, etc. (PN 59821531A, $541.00... ouch!). Locating pre-owned units can be hit or miss... sometimes they're available and sometimes not.
Thank you so much.
Hi Khmer
i have seen your youtube videos and am very impressed. I hope you can help me with an issue.
Hi all
i recently purchased a 2015 panigale 1299s.
I parked it only to find it tipped over on the right side. Camera footage showed someone pushing down.
anyway, the right mirror broke. My friend that has ducati 1299 had a spare mirror. I rode the bike to his place and parked it.
while we were trying to install the rigth side mirror I pulled the handle towards the right to get more space to install the mirror.
the throttle aluminum bar just broke off. it was probably cracked from the tip over.
we ordered the new bar and installed the throttle and the rest.
tried to start the bike and it only cranks but does not start. I have charged the battery and it does the same thing
red few forums that talk about the throttle but nothing similar to what happened to me.
i hope someone has any idea what is going on
