I don't have the code card for my 2011 796. If I disconnect the battery will the immobilizer go active when I reconnect?
Thanks
I have disconnected the leads to the battery on my 1100 EVO and never had to enter the four digit code upon reconnecting the battery. Mine has the antenna ring around the ignition assembly to read the key. Were you thinking it would lock you out and prevent you from starting unless you enter the 4 digit code?
I was thinking it may have been a possibility. It's happened on my Harley. Glad to hear you've disconnected ands reconnected without triggering it
