21 - 22 of 22 Posts
Just disable the immobiliser function in the ECU and problem solved. On this version of the immobiliser the signal from the key is Checked against saved codes stored in the dash if it is a match it tells the ECU to start the bike. If you turn off the immobiliser flag on the ECU software
it will skip all checks and just start.
21 - 22 of 22 Posts
