1 - 19 of 19 Posts
I'm thinking about changing some ignition parts on my bike ('97 900SS Carb).
The plan has always been to go for an Ignitech module (€146)combined with Nology PFC06S-coils (bottom of page, 2x€83) and NGK racing leads (2x€25). It will cost me around €400 incl shipping for these parts (I live in Europe). Another option is some Ignitech-kit (with matched coils, HAL-effect pick-up kit,...) from FastBikeGear but as they are located in New Zealand the price (incl. shipping and Belgian taxes and import duty) will be a little too high I'm afraid.
Also; recently I found yet another option: Silent Hektik. Don't now much about these modules but I've read some good reviews on them. A Silent Hektik kit would cost around €450 but on top of the Ignitech it will also include a flywheel (alu or steel), pickups, coils, and spark plug leads.
Does anyone has any experiences with these kits (Ignitech or Silent Hektik or anything else maybe)? Good advice? Alternatives? Do's and don'ts? The need for a nice ignition-discussion? Go!!!
Remember: I am looking for a good, smooth running engine. I am not interested in gaining HP (yes, there are people like that) or better performance at high rpm's. I use my bike for nice rides through the (speed-cam infested) countryside and to go to work. No track use. No top-speed rides.
Thanks!!
I used the Ignitech set-up you described for many years with a lot of success. Liam at FastBikes in NZ has written a very helpful guide to working with this system that I recommend. Fwiw, the Ignitech systems seem to be the most popular and well supported.
Given what you are looking for I would use a ignitech and the NGK race wires and then stop. Cost wise it is not bad and the wires/caps are the weak link today due to age.
I have talked to people using the silent hectic systems and they liked them but I have no first hand knowledge plus the added cost for probably little gain over what the ignitech can do for you.
Discussion Starter · #7 ·
I just wrote to Dynatek asking them about what they offer for these air cooled two cylinder Ducati engines. I'll forward any info that they provide.
Here's a link to their website ....
LINK = Dynatek Sportbike Products
:smile2:
As far as I know their coils are rather popular among Ducatisti (as you mentioned in post #5) but I can't find any info about the use of their ingition modules in '90s 2V Ducs...
They seem to have replacement ignitions for bevels but I can't find anything else.
Anyway; thanks for asking them about their products. I look forward to their answer.
Discussion Starter · #8 ·
I bought that guide a few months ago and I have to agree: it's very helpful and comprehensive. Even if you don't use an ignitech, it's a very good guide if you want to learn more about ignitions.
On top of that; Ignitech seems more popular than Silent Hektik. I did find much more info on the net about Ignitech. Silent Hektik seems to be more popular among Guzzi and Beemer riders...
Discussion Starter · #9 ·
For now I am more leaning towards Ignitech. Especially because these units are plug and play.
And I like your idea. Just go for the Ignitech and the NGK wires and go from there.
The reason I was thinking about the Nology-coils is because Liam from FastBikeGear did mention them as the best working coils with an Ignitech.
But if I may believe the Ignitech guys, their module works just fine with the stock coils as well...
And if necessary, I can always fit Nology coils afterwards.
Thanks again for the rational insight!!
IIRC all of the ignitechs I have used were with oem coils . outside of dual plugged heads all the BCM race bikes used stock coils with no issues. Add it to the list of things to dyno test one day .
As far as I know their coils are rather popular among Ducatisti (as you mentioned in post #5) but I can't find any info about the use of their ingition modules in '90s 2V Ducs... Anyway; thanks for asking them about their products. I look forward to their answer.
They replied yesterday. Nothing ~specific~ within their lineup, but if the primary and secondary resistance of stock coils are given to them they can match up one of there coil sets to work with your bike.
I'm not pushing Dyna on anyone (or any other brand for that matter), it was more of an interest on my part to provide you with an alternative, since you asked for alternatives.
So there we have it! The Dyna mystery solved.
:smile2:
..The reason I was thinking about the Nology-coils is because Liam from FastBikeGear did mention them as the best working coils with an Ignitech...
I'll be purchasing an Ignitech system very soon but don't want the extra few hundred dollar plus expense of Dynacoils or Nologies. I asked Jiri at ignitech a few months ago what to recommend and he replied: "You can to use original ignition coils or similar. We can offer coil IC-TCI-S". (see attached pic)
As my originals are over two decades old I'll buy a pair as they are only 30 Euro each.
I'll post the results after I install and test.
Cheers.
Discussion Starter · #13 ·
That shall be the famous Dyna-coils. I remember when I was riding a Monster (more or less 10 years ago) and looking on the net for upgrades, Dyna coils were the most mentioned upgrade. I never used them so I don't know if they were worth the money but they were 'the talk of the town' back then.
I thank you for that!!
But what I don't understand is this:
I followed a few threads about Ignitech on different forums and I read the unofficial Ignitech manual from FBG and what I learned from that is that apparently coils with a lower primary restistance work better with Ignitech.
First Liam from FBG tested some coils and he had the best result with the Nology PFC06S (0,6 Ohm). Now he sells custom made Nology coils PFC10S (1 Ohm I assume). Special order if I may believe him (what I do). I can't find these coils anywhere on any Nology site so I assume he has them indeed specially made for his business and he sells them as "Nology ProFire Ignitech matched ignition Coils".
So I wonder why Ignitech advices their coils (or the stock ones) with a primary resistance of 3,3 Ohm when lower primary resistance works better with an Ignitech (according to someone who obviously knows a thing or two about bike-electronics and ignitions).
Anyway; I'll try the stock coils to begin with. I'm a complete newby when it comes to electronics so I think I'll better forget things like primary resistance and stuff 'cause I don't even know what it means...
And a new one revealed!! Why are 1 Ohm coils 'better' then 3 Ohm coils and if they really are, why doesn't Ignitech sell such 1 Ohm bastards?
:wink2:
Discussion Starter · #14 ·
Cheers.
I can buy the Nology coils for €85 each...
So yeah, €60 vs €170... I don't know if the Nologies are really that much better.
Anyway; looking forward to your test results from the Ignitech.
Once I installed one myself I will post my review here as well.
But it's probably gonna be a winter project so my review shouldn't be expected before new-year...
Discussion Starter · #15 ·
And before someone tells me that I shouldn't make such a fuzz about stupid things like coils; that's just the way my brain works. Just telling me what the best option is doesn't work. I also wanna know why that is the best option.
Can't help it... I think too much.
Sorry for that.
IIRC the 3ohm coils are correct and 1 ohm are for injected bikes, don't trust that without double checking . A friend once used injected coils of the wrong type and was blowing ignition boxes on his carby. He swapped to oem carby coils and the problem went away after blowing abouot 3 ignition boxes. I was not directly involved so take it as rumor and do your homework before buying.
Stands to reason. 1 ohm is getting very close to a dead short. Placing a 1 ohm load on a circuit designed for a 3 ohm load is increasing the load on that circuit by 300%. Nothing to trifle with.
Discussion Starter · #18 ·
The Kokusans can't handle these low resistance coils. But the Ignitech apparently can.
Copied from the unofficial Ignitech Manual from FastBikeGear:
The lower the resistance of the primary coil, the faster the current will reach its maximum value. Ducatis that were fitted with the Kukusan ignition systems used high resistance coils. (3.8 to 5.2 ohms). If you want to retain the ability to put your Kukusan ignition system back in your bike you will need to stick with high resistance coils. But you are likely see a performance gain by switching to coils with lower primary coil resistance.
And further:
3-6 ohm coils – Used on old points based ignition systems and early solid transistorised ignition systems. The high resistance of these coils limited the primary coil currents and stooped the points and transistors burning out. However these high primary resistance coils are less than an ideal match for use with the Ignitech TCIP4 ignition system.
0.5 ohm to 1.2 ohm coils – Typically used on modern transistorised ignition systems that could handle higher coil currents.
P.s. I hope I don't violate any author rights by quoting the FBG Manual here. If so, I'm happy to ask the mods to delete this post. I do not have the intention of spreading this manual illegally. The manual can be found at the link above.
I have the exactfit coils, upgraded wires and plugs, and the Ignitech. The two former items definitely improved cold starting and smoothed out the mid range, and that was before I started messing with ignition curves on the Ignitech.
I doubt there is any measurable increase in power but it is night and day in terms of smoothness and roll-ons, and makes the FCRs overall more liveable.
1 - 19 of 19 Posts
