1 - 3 of 3 Posts
Anyone know *for sure* which are the right DynaTek coils for a 2009 Monster 1100s?
Obviously DS and I read in an older post that for a 1000DS the stockers are .7 ohm.
I want to make sure to get the right ones - one of my OEM coils is cracked, and I'm going to upgrade.
Any other suggestions are more than welcome...
TIA
Discussion Starter #2
What I've found so far...
Per my ever-growing multi-meter skills both of my S2R 1k coils have a primary impedance of 1.0 ohms.
I've read about putting two .5 ohm single coils wired for power in series per cylinder, so I guess I'm safe with a .7 dual output coil.
The secondary impedance is hard to gauge - I still have to re-read the thread on that, but it seems less important - it should go from 10-15k volts to 30k+ volts per output with a change to Dynatek or Nology.
Any input is appreciated.
Anyone with Any Advice?
I can't figure out whether .7 will be acceptable or not. There's no clear answer as to the specifications of the stock coil that I can find, nor is there any that I can find about acceptable variance.
Please point me in right direction if you know anything at all...
1 - 3 of 3 Posts
