1 - 2 of 2 Posts
I have an 06 S2R1000 that is having an intermittent spark issue on the vertical cylinder. The ignition coils have been replaced along with plugs and wires but the issue is still there. I can smell gas from the exhaust can attatched to that cylinder so I think the fuel injector is ok but the spark plug isn't wet. Any suggestions would be appreciated
Mate I have this same problem, my vertical cylinder only comes online after substantial riding.
I have switched spark plugs, caps, leads AND coils and nothing, the same one works and the same one doesn't. The only thing I haven't switched is the little red cables that i assume run from the battery to the coil?!
1 - 2 of 2 Posts
