The Ignitech units appear to be sensitive to what coils you are using particularly from idle to about 3000 rpm. My previous single out put Dynatech coils appeared to work better with the Ignitech unit with a longer dwell time. I suspect this could also be true of the standard coils partnered with the Ignitech as well.
My problems with low rpm stutter and misfiring weref urther exacerbated when I converted my bike to twin spark heads using twin output coils which are harder to drive than standard coils. They needed an even longer dwell than my previous single out put coils to get them working best at low revs.
My findings are a bit strange because the Ignitech should be able to drive the primary windings of coils harder than the Kukasans....but try my recommendations below and see how it works for you.
BTW the 3 ohm Dynatech mini coils turned up side down will bolt directly onto the standard coil mounting posts of the 91-98 SuperSports. Don't worry about them being only 3 ohms. Their inductive reactance seems to be high enough to not cause any problems with the Kukasans or the Ignitech unit.
Try these changes in the miscellaneous tabs page.
Set "dwell dynamic addition" to 30
Set "maximum dwell time" to 20,000 us (yes I know it seems over the top but you can cut back this figure later).
set "max rpm for dwell by lobe" to 800 (if you don't do this the change in the line above won't have any affect at revs below what ever value you have in this field).
If this works for you and gives you crisp low rev running, then incrementally reduce the "max dwell time" untill low rpm running begins to suffer.
Also worth doing before you do the above is measure the voltage between the positive wire on your coils and the earth terminal on your battery while your bike is running. This should be between 13.8 volts and 14.4 volts (the same as measured directly across the battery terminals).
If it's not (and it won't be - typically only 11.5 volts) then install a relay to provide power to the positive terminal of your coils directly from the battery. Actually this usually gives worthwhile gains even with the Kukasans and standard coils. This trick understandably works particularly well on engines fitted with high compression pistons due to it being harder to strike a spark in a higher compression environment. I learned this trick from a customer's who discovered it. Thanks Will!)
Also try setting base advance to match your fly wheel pick up point. You can measure this by putting the Kukasans back in and checking base timing with your timing light.
Note the 32 degrees max advance written in the Ducati manuals is wrong for the 900cc engines. Maximum standard advance with the Kukasans is actually 36 degrees.
Oh and two last things the Ignitech units are susceptible to confusion and permanent failure from EMI. Due to installers not doing both of the following to negate this issue these units have a worse reliability reputation than they deserve.
ALWAYS use resistive plugs or caps or leads with the Ignitech unit
ALWYS place the Ignitech Unit away from you coils and spark plug leads
Once you get your head around the Ignitech units I think you will be extremely impressed. It would really help if they got someone to rewrite their instruction guide for them and add a bit more detail and a clear explanation of things like the dwell options.
Happy to try and answer any further questions but still experimenting and learning like everybody else.
