A few months ago I purchased an ignition module directly from Ignitech. The guys there sent we a unit already customised to run with a bike (1000 engine) using a hall effect sensor. It came wired and they said it was plug and play...
I have now fitted it, but the bike will only run on the vertical cylinder? I have loaded up and run the configuration software, and all seems OK there, but it wont fire the second plug, even when I use the test tab. I have swapped over the coils, and even substituted them for a pair of known good ones.
I have sent the wiring diagram to Jiri at Ignitech who has looked over the settings (i did screen shots) and has now asked me to send the ignition data file, which I have done. They have been very responsive to emails but I guess they are away now until Monday but I really wanted it running!
any suggestions from you guys? there seems to be a lot of experience with the ignition on here...
Here is my connection list (the terminal highlighted yellow came pre-wired)
