Just really notice it this season. Been out for a few rides so far.....Idle should be in the 1000-ish range. I keep mine about 1100-1200 because of trips to over 10000 feet regularly.
There is an adjustment on the linkage to the throttle bodies, but did it just start doing this out of nowhere? I'd look for binding cables, both fast idle and throttle, before i went and adjusted anything.
+1idle should be in the 1000-ish range. I keep mine about 1100-1200 because of trips to over 10000 feet regularly.
The idle stop screw is fine to mess with. Gross adjustments will affect the sync, but it is just a stop screw. The TPS screws, thumb wheel on the link rod, and idle air screws are much bigger factors. The EFI is baselined off of the TPS with the throttle fully closed, not cables and the stop screw backed fully out.Heres a link to BikeBoy site.
The link is mostly on throttle body syc and TPS settings but idle is set after those are done on of the biggest pains when setting up injected bikes is everything effects all the other settings so it allot of round and round to get it just right.
BikeBoy.org - Ducati 4V Desmoquattro Non Linear TPS Baseline Adjustment (plus ST3)
About 1/4 way down you'll see a picture of the control side of the TB's. you don't want to mess with #7 screw that set for TPS / plate angle base setting. Yes it will lower your idle but it will mess with other settings.
Its more likely something with #12 not returning to proper rest position.
#12 is the high idle cam or some time called a choke but it not a choke in the traditional way.
