Does anyone know the correct idle RPM for a 2002 ST4s? It's been running at 1000 or below and then the stealer changed the ECU and made some "adjustments". Now it starts great but idles around 1200-1500 even when it's warm.
Does anyone know what the correct setting is?
unM0derator
Check the adjustment of the fast idle cam at the throttle body. 900-1000 is ideal.
Typically it's around 1200 rpm. Not because it won't idler at slower speeds, but at 1200 you'll get more oil flow to the heads.
Mine idled around 900 or so when I got it and it would stall occasionally so I had it bumped up to 1100 and was a huge improvement. I'd definitely stay above 1000.
The days are getting longer!
I set mine to 1100 RPM's after syncing the throttle bodies.
