Does anyone know if there is a way to run a P8 engine (separate RPM and crank position sensor) with a P16 ecu (single crank/rpm sensor)?
I have a 955 race engine that I want to try.
Not sure either if I can get an eprom that will deliver enough fuel.
Any insight would be greatly appreciated.
Thanks
Thanks, TomTom.
Do you know if the pickup on the cam gear will work?
Or do I need to swap that out as well?
Thanks
It probably is too long.
I used a 748 SPS engine cover and the engine guy had to machine the cover slightly and use small spacers on the pick up. There´s like 5 different pick ups for the old Superbikes, so it might be hard to find the proper fitting one.
