Late last night, I finished up my CycleCat bar riser install. It wasn't hard at all and my biggest problem believe it or not, was removing the grip from the clutch side bar. It was rubber glued on there, I think.
Anyway, during my test run today, I ran into an issue. About 4-5 miles into my ride, my bike started to sputter, stall and buck, then it would die. Sometimes, it would not start at all. Once started it will have no trouble idling. I can blip the throttle all day long with no ill effects.
Now here's something weird. When I turn to the right, the bike starts. But sometimes, it will start even if I don't have the wheel turned.
So I'm thinking I messed up some wires during the install. I jiggle all the wires and check all exposed connections (not that I disconnected anything) nothing makes the bike stop or sputter during idle. Only when I'm moving do I experience the stalling/bucking issue. Oh yeah, I openned the gas tank and there was no vaccume, no hissing noise.
Now, as I'm limping home (pulling over when the bike almost gets ready to die) I'm about 2 miles from home then the bike starts to run normally. I make it home but just as I pull into the drive, it starts acting up again.
I checked all wires and didn't see any mangled sheaths or wires.
I think I can rule out bad gas, since I've been on this tank for about 20 miles now.
Here's what was done to the bike in the couple of days before my ride:
1. oil change
2. cyclecat install
3. clutch resovior fluid change (not a full flush) clutch operates normally
4. brake resovior fluid change (not a flull flush) brakes operates normally
Bike was started after oil change with no issues.
Kill switch can be spun around the bar (didn't tighten it down enough) grounding issue??
I'm thinking, maybe there's a short in the kill switch...but I can jiggle it and nothing happens. Is there a sensor I missed that's tied into what gear I'm in? It seems like its fuel but electrical in nature.
I'm just glad I made it home as I don't have a bike recovery plan in place
Thanks.
