Hey guys.. newbie here from Malaysia.. i've got the bike 2 weeks ago and it's been a blast.. however, last week i wanted to setup my suspension fit for my weight, but when i check the front forks, it didn't behave as how i think it should be. I shook the forks up and down and do zip-tie test where i wrap it around one side of the fork to mark the initial position, and when i lift the handle up and release, i thought the upper cylinder would land real close to the zip-tie, but ended up about 1" above it, this is all done with the bike sitting up-right with no rider sitting, front and rear tire on the ground..
I might post a picture later to show you guys what i meant, but looks like something might be stuck in the forks??? any of you has the same issue?
