Hi,
I'm pretty sure that I'm not the only one who face to this problem, I'm sorry I could not find the same exact topic about this subject on the forum.
I'd like to see all possible replies about it but like I said I couldn't find it... Anyway appreciate for your help...
I have a Hypermotard 821 - 2013. It's on 31,000 kilometers.
My ABS is not working properly. Whenever I start the engine and raise my speed above 5-10 kph, ABS light is going off and my ABS starts to work.
Everything is normal. I'm testing it with relatively hard brake, if ABS light is off, ABS is working OK and just doing its job.
But after 1 or 2 or even 15 minutes later, eventually my ABS light is on and dashboard is looking like:
DTC 2 (what I pick for myself, not important)
ABS - (flashes)
When I test it on this situation, I'm able to block the wheel and ABS is not even working.
Sometimes I do kill-switch off and on again, restart the engine, it's just fixing itself. ABS is getting back to the work again.
Sometimes it does not.
I do want to learn your opinions and definitely need your help about this problem.
I live in Istanbul/Turkey and Ducati service is amazingly high-priced, I don't even trust them so any possible replies & ideas would be appreciated.
Thank you very much.
ABS - (flashes)
