1 - 14 of 14 Posts
Looking for a set of used wheels for my 13 Motard, seeing what other years/bikes fit.
I searched for a long time, but can't find any relative info. Any site or thread I can check?
I found part numbers correlating to axel shafts helpful as well as after market wheels specifically bst...they are largely interchangeable...running a 1098 front rim on my m821
Bst list each rim and the compatible models
Sent from my Pixel XL using Tapatalk
The rear should be compatible with any bike that has the smaller axle nut I believe.
I found a set on the auction site from a 13 Monster 796.
Can anyone confirm or deny if these will fit my 13 Hyper?
Discussion Starter #8
This is the info I got from the seller on the auction site:
Compatibility List of other Duc models
1. All Hypermotard wheels(including previous models)
2. 1199/s/r wheels
3. Monster 796/1100
4. 899 wheels
I'm assuming my ABS ring just bolts right on to non ABS wheels.....:confused:
Nah. The hub is bigger on the 2nd gen hyper to the first...ie the wheels from a street fighter won't fit my 1100 evo sp.
Sent from my SM-G955F using Tapatalk
No it isn't. I have my 2008 1100S wheels on my 2013 821.
Hmmm....goes against everything I knew....ive seen an 821 with a 200 section tyre...youd never get that on an 1100...
Without knowing what wheels are on that 821, you should be able to physically fit a 200 on the 5.5" rim. Probably won't handle well, but it can be done.
As far as I know, Ducati has 2 SSSA axle sizes. One that takes a small nut(Hyper 1100, 821), and one that takes a larger nut(1098, Multi 1200).
1 - 14 of 14 Posts
