1 - 9 of 9 Posts
I have an 08 Hyper with around 300 miles - I just got it. I take it out on the weekends and it sits in my garage Mon - fri. Lately every Sat when I go to start up the bike it won't kick over cause the battery doesn't have enough juice - I have to jump it off another battery I have. I am going to go buy a trickle charger this week, but was wondering if others are having this same issue.
Also if I pick up the trickle charger how long do I keep the bike hooked up to it. I heard people say keep it hooked up all the time but was wondering if that is worse for the lifespan of the battery.
Thanks.
Thanks.
Make sure your trickle charger has a "float" state. Most name brand chargers (Yuasa, Deltran Battery Tender) have this feature.
I Wear The Silver Badge
I have a Deltran charger hooked upto my Hyper when I am not riding it, it might sit for a while. It has been hooked up all winter and I just cranked it over last week. I think it would've started ok if I had my new O2 manipulator hooked upto the right cable. :eek: Once I figured it out (read a post) it kicked right over. On a side note, I have then same type of charger hooked upto an Suburban LAV that gets used 3-5 times a year, and I have never had issues of a dead battery.
I dont have this problem and my bike sat pretty much all winter off a tender and started up fine, bike & battery should be under warranty, have it replaced, buy a charger just because its nice to have in a pinch but dont make that your solution.
I've been using a Battery Tender for many years now and it's extended the life of my batteries. I've never had to replace a battery in any of my motorcycles. The longest I've kept a bike was 8 years (a 1993 CBR900RR) and that battery was still working fine when I sold the bike.
I keep my DR-Z400SM and the Hyper on Tenders whenever I'm not on them.
Agree with this 100%, battery charger is effectively the sticky plaster, go have the stealership sort it out.
Even if you charge it and the bike starts, I've been told that a automotive battery never reaches it's capacity again once it is run down completely. It certainly shouldn't on a bike with 300 miles on the clock.
1 - 9 of 9 Posts
