Does anyone know how many air temperature sensores there are on the Hyper 796 ?
Also where are they located ? I have heard behind the headlight and in the intake, not sure which is right...
Intake air temperature sensor is located on the intake manifold of the vertical cylinder. Don't know if there is a different sensor for ambien air temperature???
Thanks JPA, that's the one I was thinking too.
I'm trying to work out if there is a second one but it's looking like there isn't
Do you know if the IAT is the one Memjet plugs into ?
just guessing, but it must be, if that is the only temp sensor there is.
On 796 the temp sensor has two wires.
I looked at 1100's wiring diagram and it has a combined air pressure/temperature sensor which is located behind the head light. It has four wires.
