Hi !
Is there alternatives for OEM rear sprocket on Hypermotard 1100 that would look like OEM sprocket ? Small thing, but looks like many of the aftermarket sprockets are "plain" without the weight saving holes. I don`t care about weight saving, but those solid sprockets without any holes (IMHO) look dull.
OEM sprocket cost +130$ and I might wanna try bigger (43-45) rear sprocket.
I would like to go with OEM setup without quick change carrier (if that`s even possible), regular 525 chain and sprocket should be steel.
Or should I just change the chain and front sprocket ? Rear is still in pretty good shape (in my opinion). Just small notch in pulling side.
