Ok, just replaced rear shock with new ohlins. Starting working on the new ohlins forks but I can't for the life of me get the shaft out of the lower triple. The ohlins comes with two half circle clamps that you place around the shaft and then put in a vice put the triple will not budge. Anyone remove the shaft and have this type of problem? Any ideas would be great.
Thanks
Heat it with a torch near the thread end. You have to break the thread-locking compound which is heat labile....
Be sure to use something similar on reassembly.
