1 - 7 of 7 Posts
Hello all
I ordered and got all the parts of the steering dumper from the SF1098s
I want to install it on my 2015 SF848…
How should I open that two bolts near the ignition switch ???
The bolt got no “head”
Please see photo
Thanks
https://s32.postimg.org/5cdga06lh/111111.jpg
seriously?
I am not sure...its look like a big massive bolts....
Why ducati put this kind of bolts from the frist place and how they bolt it when no head is on it?
So how am i supposed to bolt / secure the arm on it?
What I did with my 848 SF was, take a dreamell and cut a straight line across deep enough for a giant flat screwdriver and unscrew it. If not then you will have to drill them out and use a bolt extractor. When you finally do install the new bolt, they will snap off at the head at a certain torque lbs. Don't get worried it's suppose to snap off, that's why the bolts you are trying to get out got there. Hopes it helps,it was a fun little project.
Discussion Starter #7
I took off the bolts! - Thanks for the helpers!
Now I have an issue with the bolt and components that holding the damper to the handlebar
I ordered original stock parts – 44,40,41,42,28 but it make no sense
The head of the bolt 44 Is too small to the hole of part 42.. even if I will use a wide spacer – it still will not make any sense to tighten the o ring…
Can someone please can take a pic for me from his bike – if you can please take the pic from the side so I can see what is the component that’s holds that unit
Thanks
Uri
1 - 7 of 7 Posts
