No need to cut anything, just get the air gun tip from your compressor and blow air betw. the rubber and the shaft, it will create an air pillow and the grip will slide right out. Do the same for putting the new ones on if is rubber also.
Whole job, 10 minutes, give or take.
I just installed new Superbike grips on my 998. Used a blade. Worked like a charm. Make sure to install the correct grip on the right clip on. One might be bigger than the other. Total time spent = 10 min.Getting DRIVEN D-3 Alumitech Grips.
Left side, just cut the org. one with a blade ?
Right side, I was thinking to let the dealer do it...
Thx!
Same as the otherAny issues...I've never done the throttle side grip before...
thx!
