Gents & Ladies,
For those of you who want to take a hand at "doing it yourself" here is how to get acceptable results in your own garage, backyard, kitchen, whatever:
Tools you need:
* Rattle can paint - colorite will send you Ducati paint (or any other moto paint based on paint codes).
* Masking tape
* Sandpaper - 120, 220, 400, 600 grits at a bare minimum. If you want the clearcoat to shine, you'll need 800, 1000, 1500 and 2000 and buffing compound.
This is what I started with, thanks to Sear's Point on 11/15 (see other thread for crash details):
Ouchie:
Step 1: Bust out the 120 grit sandpaper. Use a block or you'll make waves. For contoured places, you can use a foam block or a sponge but *resist* the urge to use only your fingers. You will make waves and the prep work is the most important piece of making your paintwork look acceptable.
Get everything smooth. The edges of all the layers of paint will start to feather together like this:
ok, now for the embarrassing part: Bondo. Yes, you need to fill those deep gouges that wouldn't get flat with sanding. Mix it up and don't get it on any tools you care about:
Tools you need:
* Masking tape
Ouchie:
