Hi guys, in my continuing quest for a 748 i've found one with a broken headlight lens. How much does a replacement lens cost? Are both sides connected or is it all one unit? I did try a search in the parts classifieds, but I could not answer my question Thanks.
I had an issue involving the headlamp on my 748. The second day I owned it a bolt from a truck busted out the lense... I recommend Gotham Cycles. That is who I turned to. Be prepared. They're not cheap-anywhere.
http://www.gothamcycles.com/servlet/the-651/Ducati-Headlights-cln--748-dsh-998-SUPERBIKE/Detail
Depending on the side, perhaps you could continue to find a broken one and switch out the lenses. They are RTVed to the housing. You must be careful though. That is... if you decide to get this bike...
If it helps to ease the pain each headlight on my Honda is over $400, through an online dealer site.
Rough, really rough for what it is. I am sure you can find a decent condition used one, but may take some time.
