1 - 7 of 7 Posts
I'm talking about the little ones that clip onto the fuel lines. And after you take them off, how do you get them back on?
p.s 93 900ss
Thanks
Do you mean the little plastic ones? I'd simply replace them with standard stainless steel screw-type clamps. Leaking gas is a bad thing.
If you want to reuse the existing clamps, perhaps a circlip tool would work. (In case you don't know what I mean, it's a kind of plier that can work in either direction, to remove or replace a circlip from either the inside or the outside of a part.)
no, they're little metal clamps and they seem to be much tighter than a standard hose clamp can get. They're just a compression type clip on job and I'm not sure if they are supposed to be reusable. I don't think a circlip remover would work as it's an odd shape.
cut them off, they are 1 time use only. i believe they are called ear (yes, ear, not gear) or oetiker clamps. can be had from grainger (kit p/n 4tx96 comes with jaw pincer tool and various diameter clamps)
distributed by grainger, fastenal, msc, manufactured by oetiker (germany)
linkee....... http://www.newageindustries.com/oetiker.asp
heres the kit..
http://www.grainger.com/Grainger/wwg/productIndex.shtml?search_type=keyword&QueryString=4tx96+&operator=refineSearchResults&originalValue=Oetiker+Jaw+Pincers&searchIndexId=1&typeOf=&x=28&y=8
Obsessive/Compulsive collector
I wonder if those are anything like the ones on my '00 M900Sie. That one had (at least in the tank it did) a clamp that resembled the one-time use pinch clamps, but would unlatch & relatch so as to be reused. I almost did end up cutting one off, till I looked a bit closer.
Discussion Starter #7
They are probably the same thing. They look like they could be reusable, but I think bigbadass is right and that they are single use items. I undid the one on my fuel vent line but never could get it latched back together.
1 - 7 of 7 Posts
